KOPBET
I am going to replace the pre-cat oxygen sensors either today or tomorrow. I would like to know what technique you use to get at the sensor on the right hand side without dropping the pipe from the manifold. I have a sensor socket that works fine on the left side but not on the right side due to clearance problems. I don't have a 7/8" wrench that will fit in that space either. I thought about using a crows foot or some other type specialized wrench, but didn't want to waste money on a single use tool if I could avoid it.
Also, the instructions want you to torque the sensor to 28-34 fl/lbs. Yeah right, good luck getting a torque wrench in there.
