Replacing Steering Wheel - scared of airbag
  • Thread starter Thread starter AIRBUS
A
AIRBUS
I'm replacing my "showing-its-age" steering wheel with a lovely original from Contemporary Corvette. Problem is, Helms says to "Install Load Tool J37808 by connecting 'Base of Column' lead of tool."
Well, of course I ain't got one of those. The battery has been disconnected since October 7th. Is it possible that the DERM has bled down to the point that the bag module (squib) is now safe? Or...do I need to get the load tool and follow the Helms procedure to the letter?
What say ye?
I've posted this in Technical and haven't gotten any hits yet.
UPDATE - I just spoke with Gordon Killebrew. The battery only needs to be disconnected for about 10 minutes for the DERM to bleed down to the point where the airbag won't fire.
Then, after loosening the two captive screws in the back of the sterring wheel, you can pull that bag out to turn it over, and simply pull the yellow connector straight out from the back of the airbag module.
Hope this helps someone in the future.
Sorry I just got back into town and would have answered your question. However, you now know that your good to go!
This info is in the FSM (HELMS MANUAL).
Mike
Mike
Thanks for responding, Mike.
I've got the manual, Mike, but without the load tool and never having seen the tool, I was just real unsure of how to go about it. Additionally, you would think the connector would pull straight out, BUT it is shape a lot like the "Faston" style that would pull from the side as though you were going to pull on the wire to remove it.
Anyway, now I'm in the process of working the wheel back and forth till it finally comes off. Gordon cautioned me to not attempt to pull it straight off with the main puller bolt as the 90s were prone to breaking. Wouldn't have come by that tidbit if I hadn't checked with him.
