Help! replacing the window motor 1981, should it work without bolting in.
1981whitecorvette
New member
Garland, TX
1981 white coupe
I got power coming out the switch with a light pole at the motor clip. I have not measured the power yet. But when I plugged the second new motor in without install it will not work. Does it ground thru the window assembly? Should it work without installing it. I'm stuck. I don't know if it a bad ground thrum the assembly or if its the switch or something totally different any help would be appreciated. This was my dads car and Im trying to restore it. Thanks
1st,welcome to CAC !!!
2nd Yes your window motor DOES have to be grounded.....
and the motor should be reversible....
you can take a wire with alligator clips on each end and find a place to ground it...
you may want to use the battery as there aren't very many places to run a ground to on the vettes.
any more questions don't hesitate to ask....
be sure to check out the L-81 registry and register your '81...
So ground it in one of the three bolt holes or where?
I got an alligator clip will one of the bolt holes ground it? Or where should I clip the ground?
one of the bolt holes should work,I believe that's where it gets it ground when mounted in the car...
