74 454
Have a 74 big 454 all original. Rochester carb original also, no changes to factory set up.
Like clockwork, after running 1/2 hour or so and engine compartment getting fully heat sinked, I get poor hesitations and even back fires out of the intake when opening the secondaries during excelleration! Doesn't matter if I open them slow or fast, low or high RPM's. Even if I keep them open a little for 3 to 5 seconds to try to get fuel purged, it still doesn't get any better. I'm pretty sure it's lack of fuel to the secondaries. BUT, this never happens the first 1/2 hour of running. I can hit the secondaries fast or slow and takes right off, no hesitations. Engine water temp is at thermostat setting. It stays right there also after the 1/2 hour and has the issue. No rise in water temp when issue occurs. I do get it a little on the primaries also when accelerating hard from a stop. Again, only after the 1/2 hour when the secondaries are doing it.
I'm thinking carb body is heat sinking? Maybe fuel pump heat sinking or starting to go bad? It's the original 1974 pump, 83,000 miles. But issue was there all this summer and last. Just got the car early last year. Wouldn't it have gone dead or worse by now?
I attached a picture of a left over part from my carb rebuild kit when I rebuilt it last year. It's a foam piece. Does anyone know what it's for? Could this be an insulation piece somewhere to help the float bowl from getting so hot? Could this be the secondary issue?
