wgm87
Ok, I've got the body off to repair the rockers with the inserts from Zip. The channels are in pretty good shape except for the actual mounting points. Anyway, my question has to do with securing the inserts. When they are in place, they do not rest flush to the existing channels. Correct me if I'm wrong, but aren't these supposed to be spot welded in place? Do I need to grind spots down to make weld contact points. I don't think the existing channels are warped, but it is possible. I have cleaned the surface rust and prepped the metal. So, If anyone could throw a few pointers on the insert installation, I would appreciate it.............
Glenn
Glenn
