S
Stryker_78
Well I tightened up my rockers on my L-48 because they were quite loose. How much play should they have? I did the pass. side first. All went well.(BTW I posted on here a few days back about smoke coming out of my passenger side vavle cover. Thsi is now gone since I tightened the rockers)
Then I did the driver side and when I started the car, it started backfiring up through the carb and the idle is very erratic. I shut the car off quickly. Is it possible that the rockers are now too tight? Maybe one or more is a bit tighter than the others? I torqued them but not exactly sure what the proper setting should be for the torquing. Can someone help me out here with this one.
Scott
Scott
