Ricks98
Having problems with a rocking driver power seat.
I found the following on the forum
HI there,
There is a bulletin on the drivers side seat moving during braking and acceleration.
This is 02-08-50-002 for the drivers seat.
Being that both designs are very similar, and only that the passenger side is not used as much.
I would just remove the 15mm nuts, and look to see if there is any play in the adjuster itself.
However, it may be covered under your factory warranty, based on mileage and in service date.
So, I would just check it out, and if it is something simple, you will see it pretty clearly.
Let us know how you make out, c4c5
__________________
Where can I find this bulletin? Any idea
HI there,
__________________
