Roll Cage info
grumpyvette
Loxahatchee, FL, Palm Beach co
http://www.nhra.com/contacts/tech_faq.html
always use slightly thicker chromemoly steel in case the rules change gusset the angles and exceed the gusset sizes, base plates should bolt and weld with grade 8 bolts to frame sections or backing plates
http://www.pdkfabrication.bravepages.com/bre_replica.htm
http://pg.photos.yahoo.com/ph/larryjohnson97438/album?.dir=/a6b1&urlhint=actn,ren%3as,1%3af,0
http://www.rollcagecomponents.com/index.htm
http://www.rollcagecomponents.com/kits/rollcagekits.htm
http://www.stu-offroad.com/guards/sportbar/roll-1.htm
http://www.burningcage.com/roll-cage.shtml
http://www.stockcarproducts.com/rollcage.htm
http://www.racefabinc.com/rollcages.htm
Grumpy, I moved this to the Autocrossing and Motorsports forum and stuck it to the top, along with the information from NHRA I posted a while ago. Thanks for the information! :upthumbs
