Roller rocker question
Kid_Again
NJ - Which exit you from?
65 SB Roadster, 66 BB Coupe
I am constantly amazed at how much experience some of you guys have...and how reluctant I am to change anything if I have the least little concern.
I just put a new ZZ454 crate engine into the '66. Nice performance. Apparantly I have this desire to make it "better" :eyerole
I have a set of roller rockers (Crane Gold Race, 1.7 ratio) that I would like to take off my old Mark IV heads and install on the new aluminum heads (they have the correct studs, I called Crane).
A buddy of mine who is technically competent (but perhaps still stuck in the '60s) says that adding RR's to a hydraulic cam (regardless of whether it's a roller cam or not) is a very bad idea because the bearings do not move enough, causing premature failure of the rockers. :confused
Now, why in the world would that be true? I've seen loads of aftermarket RR's for LS1/2 engines and they have hydraulic roller cams. I know I could ask Crane but I wonder about their biases.
What is your experience? Can you point me to any articles on the subject?
Thanks.
Roller Rockers
I don't buy that. I have been running Crower roller rockers on a 502 for nine years and a lot of miles. It has a hyd roller and has given me no problem at all. John
Many thanks!
:w
