M
mjsrun
I suspect others who have replaced head gaskets/valve grind may have encountered my problem or similar.
After setting the valve lash several times and still getting the same results of having an engine that runs lousy I ask myself what I could have done wrong in the reinstallation of gaskets, distributor, wires or other important items.
I checked the TDC with the distributor and the rotor is between #'s 1 and #8 such as the manual discribes. The exact location which I removed the distributor.
After checking the timing it appears that there is about 55-60 degrees of advance in the marks before the marks line up at approx 6-10 deg's.
I really don't know how this could happen as there is a pin under the base of the distributor that keeps it aligned up to 180deg and a mistake is literally not possible unless I am actually 180 deg off. The distributor will not go down fully if I don't align the pin at the base of the distributor. Almost a given when removing the distributor.
I checked the wires to see if one of them is mislocated and they are correct.
Any thoughts you pros might have would be appreciated
