Rubber or Poly bushings
BLACK MOON
KNOXVILLE, TN
15 Shark Grey 3LZ Z06
Rubber or poly control arm and trailing bushings. Please give me your opinions if you have used both and compared.
I used the poly once. Even with the silicone lube, the stiffness and constant squeaking caused me to sell the car. Never again. I want to enjoy my cars ride.
I agree. I only have poly bushings in my adjustable strut rods, and the strut rod vendor recommends reinforcing the GM welds on the differential mounting bracket - due to the high shear stress transmitted through the poly bushings. I reinforced the welds before installing. I love the adjustable strut rods.
Thanks for the heads-up on the GM weld on the rear strut rod mount bracket. I have a set in my '65, rear settings haven't changed in 3 yrs.
