Run or not to run
  • Thread starter Thread starter Oldgeezer
O
Oldgeezer
I have read pro and con on whether to start your Corvette or not to when you store you car for the winter. What do you do? This question has probably been here many times.Sorry for the repeat questions.:w
mark distributor
My dad (the mechanic) always told me to pull the distributor, cut a the handle off a long (long screw driver) put it in a drill and use it to start the oil pump for a few minutes. Works great on your older model vettes never tried it on a new one but suppose it is the same. can turn the crank a few times with a big wrench also.
It couldn't hurt. Usually though you will disconnect the battery when you store. Also remember to change oil before you store.
Thanks for the replys. Thanks Ctfoodguy2000, that info answered all my questions.:w
