Too HOT!
Roy: 220+ is something to be concerned about, especially here in Florida.
I had the same problem and the cause was very strange. I checked to see that the electric cooling fan was working, I reverse flushed the cooling system, changed the thermostat, checked ignition timing and checked the water pump. It still was running 220. Went to automotive electrical specialist and he found the problem. Although a visual check of the electric cooling fan showed that it was working, it really wasn't working properly. An electrical meter indicated that it was drawing too much current and not running at full speed. We replaced the electric cooling fan motor and wa-la it was fixed! now temperature back down below 200.
BTW a quick way to check the electric cooling fan is to turn on your A/C, that turns the fan on full time.
__________
Al
