running light problem
Flyer50
Jonesboro,Arkansas
1999 Black Coupe
need some help, on my 99' the right running light won't stay on . some times it works and other times it don't. I changed the bulb...check the socket....the wiring. the ground Im not sure about. where's the ground at.
HI there,
Well, as long as the socket is NOT burned and the hazards and turn signal work correctly, you can start by checking the DRL relay.
There have been a few relays creating weird problems.
Switch it with another and see how you do.
Allthebest, c4c5
