L
lnirenberg
Finally on the road and the problems begin. Work this winter included new Edelbrock aluminum dual plane performer intake w/ new 600 cfm edelbrock electric choke carb, comp cam 1.6 roller rockers and new hydraulic lifters. Engine is a base 350 that has been bored .03 over and compression raised to 9.7-1 (that work was done by previous owner). Car starts right up runs great when cold and continues to run great holding a steady 6-700 rpm idle with a nice rumble. When I shut it down and then restart it, it turns over a while before it finally catches and the idle is very rough and will stall if I don't rev it a bit. Once it gets driven a few minutes it runs fine again. Any help would be most appreciated.
