B
		born2saw
Running rough
Drove my car today for the first time since late November. At that time it was running a little rough, but I did not want to mess with it as I put it into storage. Today, I hooked up the battery and fired her up (my car will be a part of our clubs 50th anniversary display at world of wheels next weekend & I wanted to make sure she would start). She started up easy on the first try & idled great! As it was a beautiful sunny day, but cold (7 degrees!!) I took her for a 30 minute drive to lube everything up and make sure I had a full charge on the battery.
She ran great accelerating, either full or partial, pulled real strong (for a L48). The secondaries were a little hesitant but were definately opening which improved as she warmed up fully. But, when I tried to cruise at a steady speed, she bucked and ran rough. Still idled smooth at about 900 rpm. She ran a little smoother at high speed (70-80 mph) but still was rough at steady speed. Pulled strong to 100 mph where I backed off (can't afford a ticket right now).
The car is stock with about 45,000 miles. I have some minor exhaust problems--I can feel it banging & am planning to replace the exhaust system early this spring. I do not think I have an exhaust flow problem, but I think the cat is original (I may eliminate it and go with true duals-will a 74 system bolt right on?).
I know the good folks at CAC will have a good idea where to look first. Is this carburation? timing? something more serious?
I plan on taking her to my mechanic first thing this spring for a complete tune-up, but is there something I should be concerned about or have my mechanic check very carefully?
Thanks in advance--CAC rules.
