Its not bad if you have some one to help you.You cant do it with the door on,it must be removed.You will need to remove the door panel to get to the bottom door hinge bolts and the door access plate at the top to get to the top hinge bolts.After removing the bolts remove the accordian wire loom that covers the wire going from the door to the hinge pillar(body).Slide the door back ,using something to support the door and have someone hold it while you replace the door pins and bushings.The rest is self explanatory but heres a few items that will make the job easier,A center punch,aset of 1/4 sockets a die grinder,a hammer and a 1/4 extention.The worst part is that the upper door hinge pin will hit the fender before it comes out therefore has to be cut in half once halfway out.Another good idea is to take masking tape to the edges of the fender and the door to prevent chipping the edges up.Hope this helps.
