Saw BABY in the shop today
Newark, Delaware
1965 Coupe L76 / 1978 L82
Well, after some problems causing a few weeks delay as I mentioned in my thread the other day I finally got to see BABY in the shop today and some progress that has been made this week.
After talking to my guy, I think late winter or early Spring is a more realistic time schedule until she is going to be done.......SIGH
Oh well, it will be worth it.
So far he has started disassembly and has most of the trim and chrome pieces off the car. only thing left to remove that I know of is the front blinker lights, sidepipe covers, and trim rails that run along the top of the sidepipes. Pretty much all other chrome, badges, trim pieces, rear lights, gas cap cover, wipers, front and rear glass trim pieces, door panels, side mirror, door handles, windows, bumpers, grill, etc are all removed.
He has also started stripping the paint which he says will take about a week and than it needs to be rubbed down with something (i forget what he said he uses) and washed. After that it needs to "vent" for about a week to let all the paint stripper dry out of the 'glass before anything else.
After that he can start on all the fiberglass work in areas he will be repairing and rebuilding and correcting. there is a guy directly across from the shop that does media blasting and the body could be stripped in an hour or so but he doesn't like to do that on 'Vettes as he said the blasting tends to round off edges.
Already, just from the area he has already gotten the paint stripped off we have found some interesting things. First, I already knew that throughout the years 3 of the 4 fenders have been replaced but now it looks like at some point the car has a bit of rear-end damage and a new rear section was bonded in - not a whole rear clip, just the section that holds the taillights, bumpers, etc. Also, while the car has definetly been repained before it looks as if it was stripped down prior to the currebt paint as the existing paint on thr was not very much. The current lacquer paint he is removing is fairly thin but even more interesting is that at some point someone painted the car green as we can see the green underneath the current maroon color. I'm not sure how the green is still showing up if it had been stripped before this current paint job but it's there alright underneath.
After everything is stripped down, and than vented he will work on the 'glass repairs and rebuilding where it's needed. After that is the sealing and priming.
He will let that cure for a bit before spraying the base color. He is planning about 6 coats of base with wetsanding between each coat and than letting that cure for a while again before spraying with 2 or 3 coats of the clear and wetsanding again.
It looks like the only parts I need to order as replacements ( i already knew anyway) is new trim pieces for around the windshield.
I'M THRILLED!!! Finally some progress on the car after 5 weeks!
UPDATE: pics posted now.
Glad to see that you are getting some progress, at least you are getting good winter storage :D And he is taking time for the primers to vent so you don't get any solvent pop.
Tom
Barry save your money or get another job. Once that fresh paint is applied, you will want to rechrome and polish all of the stainless steel. One thing I did was took home the exhaust bezels (you go side pipes so you dont have to do that) the lights, and all the trim and cleaned and polished everything. Also, buy a gasket kit and replace the gaskets with new ones, and obviously if you can afford it replace the weatherstripping. In the long run it worth it.
One other thing to remember, PPG is the base and clear coat that we used and only shot 1.5mm of base and 3mm. If you shoot more, you can have some possible problems with blistering in the future.
If you want I can get the specifics on what I used including the primer.
TAKE PHOTOS TAKE PHOTOS TAKE PHOTOS, the work you are doing now will increase the value of the car in the future and its nice to have a complete book on the job.
Keep us informed and if I can help let me know.
OH what you are going through is still very very clear... Do not use the blast media, it WILL round the lines, paint stripping is the best method for Corvettes.
Regards....Collin
oh, in case you are interested, here is a pic that may explain why work at this guy's shop takes so long..........
see attached pic.
Currently in the shop you will see my '65 and out of view of the pic is another '65. also there is another midyear, a '57, a '62, a '72, a '69 (hidden behind the Chevy II), and the '57 T-bird. The T-Bird belongs to a member of the duPont family and has been in the family since it was brand new. He also has a few other cars being worked on that are also out of the view of the camera. This is a lot of cars for a shop where the owner is the only guy there - he has no other employees. It's good in the aspect that all work leaving his shop is up to his standards since he is the ONLY one doing the work but it does have the downside that he gets a bit overwhelmed in the amount of cars and work he has and therefore jobs take a long time.
I just thought it's interesting to see all these old vettes in the same shop.
Regards....Collin
Collin
as for the chrome, stainless, weatherstripping, etc I'm lucky there because when I bought the car in March it had just finished a complete body-off restoration. The only thing it hadn't had done to it was a new paint job at the time because overall the paint was in pretty decent shape. EVERYTHING else pretty much had been redone or replaced. We went over the car top and bottom front to back before starting on it for this paint job and really the only thing we need to replace is the trim pieces for the windshield as when they were put on last time I guess they weren't fitting just right and it looks as if they are somewhat flattened by someone trying to get them to snap into the clips with a mallet. Those pieces and a new gasket around the rear window is all the car will need as "replacement" pieced when it's time for reassembly.
Having bought the car right after the restoration is making this a bit easier.
since all the existing chrome and trim (except for the windshield trim) is all new and perfect all it needs is a wipedown to get the dust off!
Finally getting a start. Good deal. It looks like he still has room in there for my '59. Maybe I need to call him. :L
If it had some rear damage it was much easier to replace the rear tailight panel and repair the upper panel as needed. I say that because the upper rear panel includes the entire roof to the top of the windshield, the complete rear window surround area and extends to the top of the rear quartet panels and back to the rear tailight panel. This panel is just the outer skin so it would have to be seperated from all of the innner panels and birdcage then the new one bonded on. That scares me just to think of all the work involved and I have never been too shy about jumping into the middle of a Corvette with a saw. :L
Good luck on your project. Keep the pictures coming.
Tom
