Seat Covers
  • Thread starter Thread starter CS72Roadster
C
CS72Roadster
Has anybody used the Eckler's all leather seat covers? I ordered mine back on Aug 8th and the one's I received had no allowance for the shoulder strap and bezel. I sent them back and have yet to get the correct one's. Any recommendations?
CS
Buy them from Al Knoch. Quality item , fit nicely, and look good. Once you brgin to install them you will appreciate the fit. They are a bear to install and if they don't fit properly you will regret it at once. This is not the area where you want to save a couple of bucks.
If they can't get the covers right from your order they may still get them wrong and you will pay the price when you install. Knoch knows seat covers.
Are you talking about the location or holes for the seatbelt hardware and trim plate on the front top seat? When I orderd mine from Eklers mine had no holes cut on them . After I installed the cover on the backs I just cut the holes on th material to fit the seat belt hardware and trim plate. I only cut the material after I installed the hardware too. Hope that this helps
I knew I would havee to locate the holes, but the stitching was different than what I had around the bezel. There were vertical stitches that would have run under the bezel and been cut for the shoulder strap. In other words, it didn't appear there was any allowance for the shoulder strap bezel at all.
CS
I got my leather seat covers in from Al Knoch yesterday. They do look nice and are the correct ones. Finally! Now I just have to find the time to install them.
Thanks for the help.
CS
