V
vette-dude
My Service Engine Light comes on whenever I drive my 91 L98 Vette to work in the AM ( 5 Am to be exact). Let me explain. It only comes on when the temp outside temp is below 65 and it comes on at the same place on the freeway. If I shut the car off and restart, it is not on and doesn't come on again till the next time I repeat the drive the next day. If the outside temp is over 65 it does not come on. I noticed that the light seems to come on when the temp gage reaches the 170 to 180 degree normal operating temp on these cool mornings. I would test for a code but the light does not come on in the warmer temps of the afternoon drive home. My thoughts are that the coolant in the radiator stays cool and when the thermostat opens the influx of this cold coolant causes a glitch in the comparison loop feedback between the temp sending unit and the gage. The Computer then throws the light as it gets confused. Is this possible? The car runs fine with no problems even though the light is on till I turn off the ignition and restart. I don't think it is anything to worry about but just need confirmation that I should ignore it. Thanks.
Randy
Randy
