C1214
GMJunkie
Thanks for the response on my problem, and the link to "ABS/Traction Control comes on periodity"
I follow the sugestion about cleaning and lubication the "Ground Connections" which didn't make the lights go out, but I now have good clean ground connections.
Next I tapped on the EBCM unit with a small wooden mallet to help un-stick the selonoids, which was reccomended by another member, this did the trick and the warning lights went out and both systems work great now.
I was glad that this did the trick as my 03 only has about 17,000 miles on it.
Shame on GM for not building a more "Robust" ABS system, as I had a similar problem on my 97, which I solved by using the ABS system periodically to help keep the valves loosened up and the warning lights from coming on.I read a lot of good reviews about
www.absfixer.com who make a good living rebuilding the sub-standard GM EBCM units.
Tanks for everyone's input on this subect.
LA VETT (The Vett)
