6
69vettester
I just joined the forum so Hi to all on this board...
I recently bought a 69 convertible 350/300..Its a real beauty..
It had a cracking strut bracket that I removed had welded and reinstalled until I can get a new one. My question is The specs call for a 1 degree neg. camber for the rear wheels. Does the negative camber mean ,the bottom of the wheel is out or in at the bottom? I set the cams 3 different times but cant seem to get the tires back on the ground without the tire being noticibly out at the bottom. The car handles great at cruising speeds at or below 75 . above that , it sounds pretty loud and rough, is that normal? Im getting a repair manual asap but until then Ill shoot some dumb questions out on the list!
Any feedback, comments , ect will be appreciated..
Thanks..
Tom
Thanks..
Tom
