shims body to frame 1960
virginia
1960 horizon blue conv
I have painted and put back together my 60 vette and now realize I need to re-shim my car for doors to fit properly:confused does anyone have any tips to make it any easier. I am thinking I need to have it on the ground with proper size tires or can it be done on jack stands any ideas will be appreciated mike
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
Hi Michael,
If you put your jack stands under the rear axle housing and under the front lower control arms you would have the same stress as having the car sitting on the tires. Are your door gaps too tight or too loose? Does the bottom line up with the rocker panel evenly?
Tom
virginia
tom, I am zeroing in on problem the bottom gap is pretty good I have checked all shims they are pretty equal except the rear if I raise the rear of body up it does not seem to be in to much strain and it closes door gap to about 1/4 inch all around which I think is ok the only concern I have is the gap from body to rear crossmember pad is about 1" I can shim it and let it go but that seems like alot difference in shims
Tom Bryant
Administrator
That does seem to be a lot of shims. Have you tried removing shims under the lock pillar and the cowl to lower the center of the body instead of lifting the rear?
Tom
