vdogamr
So I did my first ever shock absorber replacement. One down three to go
. It took two trips to the local Shucks to get proper tools I should have already owned, and probably 3 hours longer than it should have. But it was fun, and the next one will be much easier.
I bought the KYB shocks, and they were a little shorter than the ones I replaced. I had to jack up the whole thing so I could bolt it in place. I do wonder if I incorrectly tightened the top though. Attached is a picture of the tire hanging and a picture of it on the ground. With it hanging, I thought I had tightened it too much so I lossened it just a bit. Once it got to the ground I started to think maybe I didn't tighten it enough.
Also while I had the tire up, I gave it a good spin. It made a scraping sound once per rotation. I acually think the brake rotor is loose. I was able to give the tire a good jerk and lessen the amount of scrape.
If anyone has any advice on any part of this, it would be apreciated.
