Short & long water pumps
  • Thread starter Thread starter studiog
S
studiog
Can anyone educate me on the difference between long and short water pumps? Is it just the lengh of the lower hose connection pipe? Thanks :confused
It's the distance from the block to the fan mounting surface. bobchad is right about the difference (about 2 inches) being in the 4 legs. I think the long pump started on Chevy's with the 350ci engines in 1968. Long pump, of course, puts the fan 2 inches closer to hitting the radiator.
Short waterpumps are used on 55`s to 70 small blocks and 65-70 big blocks. You cannot change from short to long as belt and pulley problems prohibit this.
