S
SLICKMAN
I’m in the process of installing new calipers and I wanted to get some input regarding switching from DOT3 to DOT5? I was told that if you switch, you need to flush out the system first, is that true?…
Vette/Berlina-coupe said:-the different grades will mix ~Bob vH
dot5 has a higher boiling point and is great for racing.GW74 said:I replaced the DOT 3 in my 74 last year. Here is my experience and my 2 cents.
Yes DOT 5 is more expensive and is now available from all the major supply houses as well as my local parts store. Because it is silicone based it does not absorb moisture. No moisture in the brake lines will ensure that they won't rot from the inside out. It will also keep the caliper sleeves in better condition which ensures a better seal and I have found that my pedal is firmer.
I pumped out the master cylinder and cleaned it with denatured alcohol. I refilled the master cylinder and bleed the lines following the Haynes Manual procedure. I used one of those vacuum pumps so it was a one man job. You will see the difference in the color of the fluid once the DOT 5 starts to come out the bleeders. I pumped plenty of new fluid through the lines to make sure all the DOT 3 was flushed out.
DOT 5 does have a lower boiling point so I wouldn't use it for racing but for helping preserve the brake system of my weekend joy ride I am very satisfied.
SLICKMAN said:Well, looks like I'm going to stick with the DOT3
Gunther said:Hi Joe,
Pls clear you private msg box, it's full.
I would require your assistance for some private matter.
Thanks and rgds. Gunther
