Side Fender??
Donne Trav
Washington, DC
1994 Blk/Blk
Hello. In dire need of LEFT SIDE FENDER for my 1994/Black.
The 3 "slotted holes" that accept the hardware for the 3 Torx screws
has broken off over time. There's no way to re-fasten the panel. HELP!:W
I have repaired 2 of these.
1. pop riveted a strip of aluminum on the lip and redrilled the holes
2. used the magic epoxy putty and then redrilled the holes
Both are still on the cars I repaired after several years. I've repaired the fender flairs for an early Trans Am in a similar fashion as well.
I'm sure a little fiberglass or JB weld would work just as well.
If you cant repair it try
vette2vette.com ask for Jason. They have salvage vette parts there and have been reliable for me in the past.
Also, if those holes are broken, I would check the battery hold down clamp to see if the battery is moving around.
Good luck, I hope this helps. :beer
You may have some luck at your local Chevy parts department.
B17Crew
:w
