Alright so i had the battery tested and yes it was a fresh battery right from the shelf it was producing 12.5 volts butttttt the cranking amps were terribly low so i got a new battery( and terminal ends since i was back there anyways) hooked everything up started right up.
I bought this car for a steal i mean it was damn near free, so i thought going into this it was going to be a money pit to even get it running no less fully restored and where i want it to be but i have now completed restored the interior including retubing the floor pan as it was non exisitant rhino lined the under carage, i have to run through the vacuum leak i have in the head lights then to paint and body this entire restore with the cost of the car has run me under 5,000$ and the motor only has 35,000 miles !! I have finally found something to motivate me in life again and the support from this web site is amazing i can't thank all of you enough for the incredible information y'all provide Thank thank and thank you again I will post pics this weekend and show you how far I've turned this thing around in a matter of a couple of weeks.
