Thanks for the info but don't need shifting advice - been doing that right on 3 corvettes 1 Porsche over 30 years. Some driving conditions require throttle handling that make the skip mandatory from the car's point of view. I will go with the eliminator.
Sorry, but I'm not buying.
I've owned five Vettes in 35 years and driven them in every condition you can imagine, from racetracks and road tests to gravel and snow-covered roads and I've yet to find a "throttle handing" issue that made the skip mandatory. Besides, if you understood how skip shift worked, you could defeat it just with your "throttle handing" and shifting, but...
I have a hunch that, in this case, explaining the proper way to operate the system is a battle I'm not going to win.
Suffice to say that there are numerous sources (MidAmerica, Corvette Central, CAC-sponsor Zip Products, etc.) for skip shift eliminators and one is required on C5 or....you have to change the cal, thus: the eliminator is by far the cheapest and easiest way.
My own cars?
My 95 has it eliminated in the cal.
My 04 has the feature in place but I can't remember the last time I had it enable.
As for this...
it is a simple way to get around EPA and gas guzzler tax and for someone to tell you that you should learn to drive manual properly because you wish to disable it is...
...is what?
The idea that skip shift exists for exhaust emissions ("EPA") or guzzler tax (CAFE) is urban legend. Skip shift was designed in the mid-80s for the 1989 model year as a way to "beat" the Federal pass-by noise standard. At the time, the test required the driver to start out in first gear, then shift to the next highest gear and go by the microphones at wide open throttle. When GM began development of the 2nd Gen ZR1, it became obvious that, with an exhaust system that allowed the engine to make adequate power, they'd flunk the test, big time. An engineer named Jim Ingle (now retired) came up with the idea of preventing an upshift to second using an electro-mechanical device in the transmission controlled by the ECM which made fourth gear temporarily the next highest gear after first. This forced the driver to go by the microphones during the pass-by test at WOT, low rpm in fourth--and quieter--rather than at high-rpm in second--and louder.
Skip shift has continued, with numerous calibration tweaks, to this day as a hedge against pass-by noise. It is possible that it contributes to fuel economy as well, but I doubt it. EPA mileage ratings are based on a specific drive cycle and I've never heard that skip shift contributes to that with any significance.
When you learn the conditions under which the feature enables (some FSMs discuss that), it's easy to drive around it and there is no performance driving situation--as long as you are properly driving the transmission--where you'll get skip shift.
The vast majority of drivers who have trouble with it are part-throttle, short-shifting out of first....hardly the way a Vette, a Porsche or any manual trans car should be driven.
You can duplicate the pass-by noise test by starting out in first in a manner that meets skip shifts requirements, then, once you in fourth, go to WOT and accelerate. Have someone stand about 50 back from the road and listen. I guarantee they'll see, uh....
hear the advantage of skip shift.
