Soft Top Rear Bow Stay Cable
  • Thread starter Thread starter VETTE1973
V
VETTE1973
Does anyone know about this on the soft top(Soft Top Rear Bow Stay Cable), is it needed? and where is it located? Also does anyone know on my 73 the rear latch on drivers side is hard to unlatch is there an adjustment. Any help on these.
Thanks in advance.
There are a pair of the cables; one on each side. If memory serves they provide tension for the top material. Use them.
Sticky latch could be rod adjustment. The assembly instruction manual (AIM) shows the decklid hardware.
Thanks Mike, are these also called the tension cables?
You may have to unscrew the pins on the top a couple of turns to get it to unlatch easier. Then when you pull the handle to unlatch the top you can push down on the top then lift it up.
