B
barrynk
Does your Corvette C5 deck lid only pop open 1/4" ?
For those whose deck lid doesn't pop up far enough to open with your fingers, you might want to try this simple solution at http://www.c5trunkpopper.com.
It's an additional spring that mounts to the latch, and allows the trunk to pop open almost an inch. I tried lubing hinges and adjusting latches with no results. Adjusting the bump stops caused the lid to not sit flush with the rest of the trunk, something I didn't like. Some have had good luck with replacing the struts.
This $12 solution pops the trunk open about 3/4".
Thanks,
Barry
Posted with permission from Rob, site administrator - Thanks.
Thanks,
Barry
