just went to drain the coolant but when I went to loosen the drain "wingnut" on the botton of the radiator (drivers side) it just freeturns around the threads and it won't open to drain. even if it did open now I wouldn't be able to close it again.
There is a nut at the top of the threads tightened up to the bottom of the radiator. Can I loosen that to drain or if i do that will it not be able to tighten up again? Basically I don't know if that is just a nut on a stud that is tack welded inside or it's not tack welded if I were to loosen it I may not be able to close it tight again.
How to drain the radiator if the drain plug can't be opened.
Geez, nothing can ever just go easy for me can it??!!
