Spark Plug Wires, is anythin larger then 8mm better??
S
Shadowing1985v
i just got new wires
i got 8mm why do some of u people get 8.5 or 9mm does this work better.. or something,,,
Tallahassee, FL
none right now :(
basically, The larger you get, the better the ability to flow power to the plugs, and generally there is less power loss... In my opinion, The regular plug wires are fine for a close to stock car... even up to 100 HP over stock they should do fine... I would just stick with what you already bought
BigRed
Edmonton
1985 Bright Red Rocket
My mechanic told me that if your a Mod/stock guy 8's are fine but if your running a complete ignition system or a higly modifiyed engine Taylor (For example) 11mm's are the way to go. (If I remember for a computer control car with over 400Hp you want the 11's)
D
drcorvette
Spark Plug Wires
I myself would go exclusively by what the Haynes Manual has to say. :J
B
boblx2a
Spark Plug Wires
At the risk of drawing the ire of some techno junkies I would guess that we are dealing with I squared R losses in the spark plug wire material.
I squared R losses try to explain how much resistance there is in a given length of wire at a given thickness. Since spark is mostly voltage and not current I would guess that the size of the wire, no matter what the configuration, is hard to jusitfy. Since most wires are less then a couple of feet long I doubt there is enough current flow through those wires for resistance to become a factor, especially between 8 and 11 mm.
So I would say to buy whatever wires are the right color and price and not to worry about the size of the wire.
Unless you are running your distributor from a remote site. :)
Hope this helps............
JT ZR-Won
Bradenton, FL
'90 ZR-1 #3010
When I had my L98 car I ran a Hypertech supercoil with Accel 8.8's. Right now I'm using 8.5's on my car
Jay
D
Drewser
Re: Spark Plug Wires
Bwahahahahaha:L :beer :drink :SLAP :blow :J
D
drcorvette
Sorry Drew ....
Couldn't help myself !!!!:beer
Ken
Gone but not forgotten
Hermosa Beach, CA
1987 Z51 Silver Coupe
Talk about overkill...
I ran into a guy recently that had 10.5 mm wires on an otherwise basically stock engine. That's Funny Car territory! :L
_ken :w
-=Jeff=-
Bartlett, IL. (Chicago Suburb)
1990 ZR-1
I solely use MSD Super Conductors on my vette.. they are 8.5mm
I
intruder9
For a somewhat biased review, try this link;
http://www.magnecor.com/magnecor1/main.htm
Got a set for the '91 and, along with a couple other ignition upgrades, I am seeing a major improvement in overall performance.:)
For my next modification, I'm gonna put some racing stickers on the 'vette! From the looks of some of the "Hotrods" on the streets around here, that alone will turn my baby into a major "racecar"!;)
silversport
chicagoLand, Il. USA
2001 QuickSilver Coupe
Spark Plug Wires
I just got a set with wires as thick as your forearm...they won't fit under the "beauty covers" though...
