scotth48
I hav a 1993 C4. I had some stumbling on my second fillup on vacation of about 2200 miles. After using some dry gas and now several fillups later it has improved. I thought at first ut was a fouled plug or bad wire. The engine has about 37000 miles on it as it was a replacement engine. The ebgine had about 32-3300 on it when I installed it. i transfered over my fairly new Dynaspark I had on the previous engine that had about 400 miles on it at time of swap. I put in new NGK 55GP plugs set at .047 usinf a feeler gauge as I didn't hav a wire gauge. I remove the plyg and looks ok other than it is a darker redish brown color to a normal lighter tan than normally have. Should I be concerned? Fuel pressure is at 42-43 psi. Currently have a k& n air filter and new O2 denso sensors put on prior to vacation. 2176 mies on vacation and averaged 27.89 mpg. Was disappointed in my mileage ate the fuel economy run at Eureka Springs Corvette Weekend as it was running ruff and stumbling, so had to shift down more than i thought had it been running better. The winner was at just over 29 and I am sure had it been runring better i could have. But what about the plugs that warrant a change or symptoms somewhere else?
