Ken79
- Joined
- May 24, 2004
- Messages
- 28
- Location
- East Schodack, NY
- Corvette
- 79 L82, 4Spd, Silver/Red, 1-owner, 25K mi, 2011 GS Coupe, AT, Red/Blk
I have an all original, 79 L82 4-speed, 3.36 gears, that I purchased new. The speedo has read too low since day 1 - it reads about 70 when running at 75 actual mph. I pulled out the original speedo gear and found it to be the 20 tooth blue one. Could not find one at Carlisle, as the vendors do not bring these simple things there. I'm getting ready to order one from one of the usual parts catalogs. After looking at many catalogs, most do not tell you how many mph each tooth change represents. But, in 2 vendor catalogs that do tell you the mph impact, they conflict. One catalog says a 1 tooth change = 1.5 mph change. Another catalog says a 1 tooth change = 5 mph change. I know I need to go from 20 teeth to fewer teeth. Both catalogs cannot be correct. There is a 19 tooth natural color, and a 18 tooth brown color, available. Problem is, which one to choose?
Can someone advise with certainty on how many mph 1 gear tooth tooth represents?
Thanks, Ken
Thanks, Ken
