you should be able to reach up in behind and reach them.although you may want to contact a yogi first,
seriously, just reach up behind the speedometer and pull out the entire socket.the dash bulbs have a grey wire, if you pull one with another color,make sure it goes back where it belongs(left signal)the grey ones can go back in any grey socket.
If the bulbs are good don't worry, check the contact on the bottom of the bulb,and socket, make sure you clean the tip of the bulb.almost none of mine worked, but all but 2 were good.just needed cleaning.you may as well fix the bulbs in the console, some of them are probably burned too.mike
p.s. if you take the bulb to the autostore and don't say corvette, they're only about 40 cents each.
