Ludigdrums
Hey all...so, I've been have speedo problems for some time now, and come to finally see that it was the drive gear. A couple of teeth here and there were missing, causing my speedo to flop around quite a bit. Turns out, my blue drive gear is a 10 tooth (although I had thought it was an 8 tooth). So, with my new wheels and tires, and also not knowing the prior history of my car...I wanted to set the speedo straight. Using the calculators on the net, I figured that I need an 8 tooth drive gear and a 17 tooth driven gear.
I finally found a tranny shop nice enough to look through their parts and find me the "discontinued" from the dealer drive gear that I needed. He ended up just giving me a 10 tooth and 8 tooth.
Point of the story is, the speedo still reads 10 mph too slow (which I can't see how is possible). The one good thing is that the speedo is now steady. Although, it still moves a little bit when you hit a bump, or when you get into the much faster speeds like 85-90 and up.
I should also mention that it is a 165 MPH guage. I know for my '81 the stock only went up to 85 MPH, so this is obviously a replacement/upgrade.
Should I be assuming now that it is the speedo itself. I know that the gears are all good, the cables are all good, the transducer is around a year old and works fine.
Like I said, even if the speedo itself is screwed up, I can't see how it wouldn't be relative to gear changes ya know? Very strange!
By the way, my tires are 285/40/18 which gives a diameter of 26.98"
Thanks for any suggestions in advance!
- Jeremy
- Jeremy
