S
scheasbro
Woe is me!
I cannot for the life of me remove the spindle from my 79 Vette. The four 9/16 nuts and cotter pin have been removed from behind (near the driveshaft). But, I'm told that removing the spindle via conventional means (tapping with a hammer) will cause damage to the spindle because the bearing, seal and spindle are bonded.
What are the consequences if I used a slide hammer with a plate that attached to the remaining two wheel studs and slap hammer it out using even pressure?
I cannot find any information that shows a diagram of the insides or an explanation of how to remove the spindle without damage.
Any help would be great. But, as for now, I've given up and given in for the night. The only thing I've gotten are greasy hands and a few less hairs on my head! *L*
Thank you in advance.
