Sports Seats
C
Corvettechick
I have a 94 vette and the lumbar works in the seats but the side panels do not work, any ideas? The motor runs but it does not move on the drivers seat.
Rabbit
sonoma ca usa
2004 C5 coupe, MSGM & 2014 Cad SRX Crystal red
Been looking thru the manual & the only thing they recommend is to check the vacumn lines re: leaks. etc. Take the seat cushions out & see what you can see. I may be wrong , but apparently the bolsters are operated by a bladder & are released by a return spring?
vigman
Motor head!!!!
Valencia, CA,USA
Chick....
You have to remove the seat back ( and I'm not 100%sure on how to do it..and the book is clear as MUD)
But there is a motor to widen or pull in the bolsters which is cable driven.. you have to inspect this.. sometimes the cable housing just unscrews... sometime it SNAPS.
Sorry that's the best I can do in this area.
Rabbit.. the Lumbar is the AIR bag bladder in the center section of the seat...Chick is talking about the sides ( wings ) of the seat.
Vig!
C
Corvettechick
Thanks, yes, it is not the lumbar support but the sides. The motor seems to run but they do not move.
Rabbit
sonoma ca usa
My 95 manual speaks of the "bolster bladder". So I guess there is a bladder in each bolster that is operated by the air pump & returned to the open position by some kind of a return spring. Thje manual
is really lacking in this portion. No definitive diagrams of any of the hose routings, etc. If you find
a problem pls let us know.:w
