Hi All, any opinions are welcome! I'm a rookie at ECM & FI cars & ZR-1's. My 90Z has a sputter &/or miss but it starts up & runs, no SES light. I did the following:
Looked for codes in ECM & CCM, none in either place. Used Gordon's jumpers.
Pulled all the plugs, 1-7 plugs were charcoal on both electrodes & center porcelians. Even # plugs were charcoal on both electrodes but center porcelians were snow white?? No fouling, deposits or crud or broken stuff or raw gas on any of them. My observation, entire even # bank is lean??
I then did a Fuel pump pressure test using chart A-7 in Helm. My results:
KOEO, FP2 fuse pulled, 44PSI. PSI holds for 15 min., then I released it.
KOEO, FP2 fuse in place, 44PSI. PSI holds for 15 min., then I released it.
KOEO, FP1 fuse pulled, 44PSI. PSI holds for 15 min., then I released it.
Engine idling, both fuses in, water hot, PSI 42 to 44, gauge danc'in severely in that 2PSI range. Shut down & PSI holds for 15 min., then I released it. Book says good pumps are 48 - 55 PSI on all tests, and should hold steady after pumps are off but book doesn't say how long they should hold PSI.
My interpretation of results: Both pumps are weak? Both pumps are weak by exactly same amount?? The only thing they have in common is pressure regulator, could regulator be bad??? All the even bank injectors are bad along with the pumps & regulator. I wouldn't have expected to see the gauge dance with the engine running? No fuel in the Vacuum hose on the regulator & the hose seals well. I replaced the MAP sensor hose just to make sure of a good seal, no dice. I swapped out F filter, no dice. I will pull some vacuum on the regulator & MAP just to see. I swapped in plugs, no dice.
I don't have much faith in my diagnostic abilities so I don't know what to make of the fuel pressure tests. My eyes tell me it's a lean condition but I just don't know.
I'd be greatfull for any input, thanks. Sorry this post is so long!
Tom
Tom
