Squeaking clutch pedal
8
87mark
96 LT4. Clutch pedal squeaks when moving it in and out as in shifting. Getting worse. Where do I lubricate and what is the best lube to use? Your help is greatly appreciated.
Best,
Mark
Paul G
Griffith, IN, USA
96 CE LT4 Convertible
My 88 was doing this. Kind of a squishcreek sound. Anyway remove the lower dash panal and spray some lube on the clutch pedel shaft where it passes through the fire wall. There is a rubber boot on the shaft that was making the sound. Since it is rubber I used silicone spray. No more squishcreek.
Paul G.
J
johnny
Thanks Paul,
I have the same problem.
86 tpi zf-6 Modified L98 270hp & 317 lb.ft Rearwheelpower
Missoura Ozarks
2012 💯 4LT GS Roadster
Mark . . .
:upthumbs Welcome to :CAC
How long have you owned your LT4?
8
87mark
I have owned it since January of 2001. Great car.
WhalePirot
SoCA
1984 White Z-51/ZF6-40/Shinoda body
Mine required some white grease on the pivot.
:w
