Dave,
Here is a link to when I did
Phase II on Rare
Dave L. said:
I'm going to replace all the carpet and insulate the floor in my '81 this winter among some other things. ..... ..
I'm going to treat the area with Permatex rust treatment and then paint with Rustoleum or similar coating.
The carpet kit I have chosen comes from Mid-America. It has the padding and reflectix heat material attached to it.
I'm also going to purchase from Home Depot additional reflectix to glue to the floor.
How am I doing so far?
I'd like any advice on how to remove the carpet from the back of the seats and side console panels.
I'm going to purchase new rear console doors with carpet since mine are a little beat up. At least I won't have to worry about removing the carpet from those doors!
Also,I'd like to repaint the seat shells. Has anyone advice/experience on this? Do I need to sand,primer or can I just clean and paint?
One last question is what paint should I use? Is the Mid-America dye/paint good stuff?
Thanks in advance for your help
Sounds like you have everything under control
I used the old side panels for a pattern and used 1/8" pressboard then glued the new carpet to it. You can leave the carpet a bit long on the front, rear and bottom of the new panel for a more blended look with the floor carpet.
I use 3M spray glue on the reflective and the carpet panels. First fit everything then fold back and glue as you go smoothing out the carpets to fit snug.
The rear compartments ... the new ones come with press wood (particle board) inserts already carpeted. They also come with screws holding the panels in place. I removed the new wood panels and used my old panels in the new frame.. the old ones are plastic/glass?? with the original stickers... also used the new carpet from the carpet set..
I used two putty knife's to remove the rear carpets from the seats.. then cleaned it up, taped off the carpet insert area then painted the frame with vinyl spray from True Value
then when I set the carpets in the insert, I used 3M spray glue and 50lb bags if water softener salt to compress and keep the corners from rolling up.. even with that I had to go back and use Gurella (sp) glue for the corners ... using the salt bag treatment again
I used 2 layers of reflectix in most area's but ended up removing it from under the seat as the seat dragged on the carpets
I also used JB Weld and aluminum strips to the screw points on the side panels, then placed the new panels in place marked the brackets and drilled them so I got a fantastic fit.
Leave carpets a little long or big, and trim last, once you cut the carpet, it's too late if it ends up short or too small
This is a great project, the finished product makes a world of difference..
Bud
