Ej46
Hello everyone
I have a starter/flywheel problem. It doesn’t seem to mesh right. I have tried 1,2 and 3 shims. I have also shimmed just one side, different end caps and still it doesn’t sound right. The car will start but after a while the gear on the starter will bend over and it’s time to call the flatbed to get home. When the starter engages the flywheel, only about 1/3 of the pinion gear goes into about ½ of the flywheel. And the pinion gear is out as far as it can go. Is it possible that someone has put the flywheel on in reverse and that’s why the starter doesn’t fully engage the flywheel? Can it even be put on in reverse? I don't know what else to try.
1976 Corvette
350 L48, automatic
Thank you for any ideas.
Earl
1976 Corvette
350 L48, automatic
Earl
