Starting In Neutral
Northern Indiana
1987 Z52 Black Convertible
I just got done changing the oil in my 87 and started it up in Neutral and it rolled up about 4-5 inches before it came to a rest. Is this normal? I have never noticed it before, but have never left my foot off of the brake while starting it, and yes it is an automatic. Thanks
Justin
It is real common especially if the trans fluid is cold. I have even seen some stick trans. do it. I have always felt that it is an indication of a good tight transmission.
I am sure glad of that. I started mine in neutral in the garage, and had to quickly grab ahold the the car so it didn't roll in to my tool box. I have had the car up on jackstands and started the car in neutral and the wheels started turning.
Craig
If you plan on starting the car in neutral, is a good idea to have the park brake set.
Well then I can sleep knowing I don't have to spend more money on the car to get it to run. Thanks
Justin
Cold xmsn fluid does not let the the tq converter slip like it does when it is warm and will roll a little, also holding the brake pedal down when starting a feeling the brake pedal go towards the floor a little (releasing a little) is the test to make sure your brake booster is working..
dave
If you notice when you start a cold car with it in park and do not hold the brake down, it will do it as well.
dave
Best thing about a manual transmission is that it is always under control... :) :) :)
unless you start it in neutral w/o the parking brake set. :Steer
