I'm having some problems starting her up, just every now and then, doesn't matter if its hot or cold. I'm sure part of the reason is bad gas...previous owner didn't stabilize the fuel & its been about 4 months since any new gas gone into the tank. I figure there might be some gum/varnish buildup. I got some Gumout® Regane® Complete Fuel System Cleaner hoping that will help. Anybody ever use this product?
I will also go ahead and change the fuel filters. I've seen paper and bronze filters. Any reasons as to which is better and why? The bronze cost an extra .25, so I'm assuming it's better. But I'm on a tight budget and don't wanna overspend :Silly
Plug wires are brand new, plugs are OK, but I got new ones that will be going in this weekend. AC Delco R44T
Battery tested OK, although it seems to drain fast after a few failed staring attempts. It's some generic Lastacell w/ 650 cca.
I'm also still having problems with a gas leak, I now discovered that there are two small oily gas pools on the left and right side of the intake manifold. They appeared after my failed starting attempts...I tightened up the bolts mouting the carb to the intake, but I guess I must have overtightened...
I think I'll get a new gasket and then torque to spec. I've seen carb gaskets at Doc Rebuild for $20 described as THICK and with one big opening. Zip has 'em for $5, but they have 3 openings...any opinions?
Thanks!
Thanks!
