tommer
New member
I am glad i found this forum with a great knowledge base we can help each other . I have not seen this problem posted yet but will make sure I follow thru with this post so the next poor sole who has this problem has a chance or a clue cause I dont. 2001 vette started stalling while driving for no apparent reason cruizing down the road 50 klm /hr boom engine shuts off. This happened sporattically 3 times then recently while shuffling cars in driveway decided not to start at all. If I wait at least an hour It will start and drive for 5-10 min at a time then cuts out. It will crank fine but not refire made sure battery voltage is above 12.5 ,fuel presure at 57psi , NO CODES set, new plugs and wires, fuel pump jumpered runs ok, OTC Gynesis connects ok with no codes . Yet the when it decides too it will start ,idle and run perfectly for five to ten minutes and then shut off by itself and not restart unless it sits for 1 hr. With no codes set at all either in history or current I am baffed by the fact there are no codes yet it shuts down on its own.Tried new key with new chip same deal. Tried unpluging MAF just sets a code and does same thing. I have not taken a car to Mechanic in 16 years cause I enjoy solving myself like you, but i am getting close now, any Ideas ? AHHHHHHH Thanks
