Help! Steering adjustment.
Missing Lenk
harbor, oregon
Been looking at the front end changing out wheel bearings and noticed as I turn left and right all the way some of the steering arms are coming in contact with some things hah. Sorry for the crude explanation and the crude picture I'll attach. But how can I adjust the steering so it won't steer that far to come into contact with anything.
Can’t really tell from your photo but if you look at the steering knuckle where the tie rod end connects sometime there are two holes. If your tie rod is in the hole closest the wheel it can be removed and placed in the adjacent hole further away from the wheel. This will unfortunately decrease your turning radius and mess up your toe adjustment on your alignment. Or if im not mistaken you can just loosen that retaining clamp on your tie rod and rotate it 180 degrees then re tighten it. that would be the first thing I’d try. Good Luck. Kurt<o:p></o:p>
