Steering Box adjustment (and I searched)
TWINRAY
Long Island, NY
'67 Goodwood Green Coupe, '69 Lemans Blue Roadster
I don't want to make this complicated. I want to loosen the adjustment and see if my steering wheel will return to center better. I have "like" no play. Can I just loosen the lock nut and back out the adjusting screw 1/4 turn and then retighten the lock nut. Does the lock nut serve any other function other than securing the adjusting screw?
The first question is why is it tight or stiff? If you adjusted it alreadythen yes you can loosen it but I would only try 1/8 or 1/4 turn first. If you did not adjust it already then you need to find out why is it tight. Bad ball joints, etc..
Good luck
TWINRAY,
Here is an Article from our Knowledge Base, which can be found under the Tech Center Tab at the top of the page ;)
Hope this helps.
Bud
Good luck
No I never adjusted it "in." My steering return stiffened up last year after I put a HD Moog Idler arm in, along with new tie rods and a new p/s cylinder and valve. I centered the valve and it seems to work properly. This year I put in Poly a-arm bushings along with new Moog ball joints. Personally I think everything is real stiff especially the Idler arm. I just wanted to see if the steering box adjustment would make any difference. Thanks
Adjusted the steering box screw out 1/8 turn. Also knocked down tire pressure to 28 lbs from 30 lbs. While still not like I want it and alignment has to be redone at least to get the steering wheel pointed straight (now over the top 1" - 1 1/2" on a straight flat road), much improved over before. At least the wheel returns somewhat - still along way from what it should do. Will go down another 1/8 turn for a total 1/4 turn and see how the ride is.
to make a refined adjustment...
:nono -best to make that critical steering-gear adjustment at least with the front-tires off the ground in straight-ahead position only (-in fact, you can really best feel the preciseness of your adjustment when you remove the Tie-rod from the Pitman-arm), --then preferably with the steering-wheel removed, you can you really get a true-feel for any excess-loading the adjustment may be imposing upon the internal-rollers & ball-bearings by using your thumb & fore-finger to turn the steering-shaft free of the inertia-effect exerted by the steering-wheel (that way you can feel the very subtle internal action/condition)... :dance ~Bob vH
I had a 79 Camaro in to be aliagned way back when. The mechanic asked me if I wanted it setup like a Z28. He said it would be much more rsponsive, but it would not return to center without my assistance. He was right! Turned on a dime, no tire wear, but didn't return well.
Is it possible that you need to get that aliagnment first before you rely on the box adjustment?
The key contributor to steering returnability and self-centering (and straight-ahead tracking) is front caster; get it set at 2.5*-2.7* if you have power steering, and no less than 1.5* with manual steering. It'll make a big difference.
