1- Check alignment
2- Check/adjust power steering control valve- out of balance will cause a faster feel in one direction over the other.
Loose steering, binding steering
1- Check front end parts, should be part of a good alignment
2- Check the rag joint for looseness,wear, "S" shape
3- Steering box- look at the lash screw in the cover, does it show any threads over the jam nut?
I would balance the control valve, if you see leaks check the hoses and the valve. I would not buy a rebuilt valve, buy a new one if needed. Lay new hoses over the originals to check the radius and lengths, they vary.
