R
Rollin's65
Quess what I did?
Started in on restoration.. I couldn't imagine that it would be a problem to jack up the front end at the side frame forward of the cross member to check things out. Placed a couple of jack stands high enough to get front 2 tires off the ground.
Both front tires hanging down and what do I see in the morning? All of the lube has drained out of the steering gear box.
I've never had this happen with any other vehicle I've had.
I'm going to need a rebuilt steering gear box and a lot of help on how to take it off, put on replacement and not have it happen again.
Where is the best place to get a "quality" part.?
Sure appreciate the help
Special thanks -- Rollin
